GS-Base 15.2 has been released.
Postby citadel5 » Fri Oct 09, 2015 9:48 pm
Fixes:
  • When using the "Find & Replace" command, after switching the "Plain text" searching mode and when using the "Replace All" command, the confirming message box always shows "0" as the replacement counter.
  • The "Replace" command that replaces all occurrences of a given pattern in a single field no longer displays the confirming message box.
