Date Search
Discussion of bugs in GS-Base
Date Search
Postby martyn » Fri Feb 17, 2012 7:37 pm
Hi
Can't get GS Base to date search a column of dates using dd/mm/yyyy format. Seems to search ok otherwise.
Regards
Martyn
martyn
Re: Date Search
Postby citadel5 » Sat Feb 18, 2012 10:08 am
If this is a standard date field (a text field using one of the standard date format) then:
- In simple search filters (the first option in the "Search" window) you can enter either the generic date/time strings (e.g. YYYY-MM-DD) or strings in one of the standard date strings (which will still be converted to the generic ones).
- In search expressions/formulas you can use the generic date/time strings only.
Return to GS-Base Bugs
