Copying records from one table into another
Discussion of bugs in GS-Base
Postby martyn » Sat Feb 18, 2012 12:44 pm
GS hangs when I try and do this with more than one record. Even then it sometimes pastes the text but omits numeric values.
Kind regards
Martyn
martyn
Re: Copying records from one table into another
Postby citadel5 » Sat Feb 18, 2012 3:16 pm
Thanks for reporting this bug. Yes, unfortunately there was a typo in the code. As a result, when pasting numeric fields within the table view three random things can happen: the pasting is ok, numbers are ignored or the app hangs/crashes/quits.
The bug was already fixed. You can download the updated file. The current file version is 9.0.4.
Postby martyn » Sat Feb 18, 2012 3:34 pm
Super!
Thanks
Martyn
martyn
Return to GS-Base Bugs
