GS-Calc 14.6 has been released
Postby citadel5 » Sun May 31, 2015 1:36 pm
  • The "Insert Cells" and "Remove Cells" commands have been added to the "Tools" menu.
    http://www.citadel5.com/gsc14.6/gsc14.6_tools.png
    http://www.citadel5.com/gsc14.6/gsc14.6_cells.png
  • The "Tools" menu items representing various "Insert Columns/Rows" variants have been replaced by a single command that displays a dialog box with all the corresponding options.
    http://www.citadel5.com/gsc14.6/gsc14.6_cols.png
  • The "Tools" menu items representing various local (workbook) overwrites of the global update options have been replaced by a single dialog box.
    http://www.citadel5.com/gsc14.6/gsc14.6_update.png
  • The "Insert > Date" command now displays a dialog box with a calendar control enabling users to choose some specific date, to specify the long date format, to include the current time and to specify the time zone. Similarly, the "Insert > Time" command enables users to specify the time zone.
    http://www.citadel5.com/gsc14.6/gsc14.6_date.png
    http://www.citadel5.com/gsc14.6/gsc14.6_time.png
  • Two new help sections have been added. They describe in details how to use splitted views, how the "manual" and "automatic" splitting modes work and how to use the synchronization commands/options.
  • A number of shortcuts used in L.O. and Excel have been added. For example:
    CTRL+SHIFT+Plus Inserts cells.
    CTRL+SHIFT+Minus Remove cells.
    CTRL+; Inserts date.
    CTRL+SHIFT+; Inserts time.
    CTRL+SHIFT+$ Applies the Currency format with two decimal places.
    CTRL+SHIFT+% Applies the Percentage format with no decimal places.
    CTRL+SHIFT+^ Applies the Exponential number format with two decimal places.
    CTRL+SHIFT+# Applies the Date format with the day, month, and year.
    CTRL+SHIFT+@ Applies the Time format with the hour and minute, and AM or PM.
    CTRL+SHIFT+! Applies the Number format with two decimal places, thousands separator, and minus sign (-) for negative values.
  • Some minor changes/fixes: the default grid color is darker now, a few labels in dialog boxes were slightly truncated in some screen configurations.
