GS-Calc 15.1 has been released
Postby citadel5 » Tue Aug 25, 2015 12:59 am
September 14 - 15.1.1 Update
  • The "Drop-Down Lists" dialog box has a new option: "Multiple Selection". In the "Single Selection" mode lists work as previously. In the "Multiple Selection" mode you can use the Ctrl and Shift keys (plus clicking) to select multiple list items / range of list items and the selection is accepted by pressing Enter or double-clicking.
  • Fixed problems with resizing of the "Drop-down Lists" dialog box.
  • Fixed problems with the workDay() and networkDays() formulas: if the optional user-defined "off-dates" list were specified, GS-Calc ignored their "year" values using the current year instead.
