Freeze cells
Discussion of features in GS-Calc
Freeze cells
Postby martyn » Mon Jan 02, 2012 8:06 pm
If this function is present, where can I find it, please. If not, please consider adding to future versions.
Thanks
Martyn
martyn
Re: Freeze cells
Postby citadel5 » Tue Jan 03, 2012 10:46 am
The "freeze" functionality available in older versions was replaced by multiple pane views. It seems this is a more flexible solution. The panes are opened/closed e.g. by dragging the splitter lines. By default horz. adjacent panes have synchronized rows and vert. adjacent panes have synchronized columns. (One can override this and create any synchronization patterns for all available 100 panes for each worksheet. The "View > Pane Layout Templates" commands enable you to make it all automatic.)
Return to GS-Calc Features
